Введение
Is your HP Stream - y010nr screen not working? Did you accidentally drop it and break the screen? This guide will show you the proper steps to remove and replace the screen so it will be back in working condition.
Выберете то, что вам нужно
Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
Take the opening picks and push them into the seam between the keyboard and the laptop casing.
Go all the way around the laptop.
Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
Remove the keyboard.
Using your fingers or a spudger, pull the battery cable from its connector to disconnect power from the motherboard.
Insert iFixit opening picks into the edges of the screen to break the seal between the screen and bezel.
Peel the hinge up by sliding iFixit opening picks left to right along the hinge.
Disconnect the screen from the motherboard by pulling the display cable from its connector.
Unscrew the four 0.4mm screws surrounding the display using a Phillips #00 screwdriver.
Gently remove the screen from its holding and lay the screen down on the keyboard. It is still attached to the computer.
Take the tweezers and push up on the small connector to the left of the webcam.
