Введение
Quick 10min guide on how to replace the battery on the HP Stream 13
Видео обзор
Remove the five screw covers across the back edge of the laptop
Remove the 13 screws that hold the base in place.
Carefully pry up around the edges of the laptop. Take your time around the ports as they can easily get damaged.
Slowley lift the top case/keyboard upwards and disconnect the three ribon cables.
Disconnect the battery from the main board.
Unscrew the 8 screws holding the battery in place.
Еще один человек закончил это руководство.
