Введение
Whether you want to replace a faulty keyboard, or you simply seek to change the look of your notebook, this easy-to-follow guide will instruct you on gaining internal access to the HP Stream 13-c002dx in only two steps.
Выберете то, что вам нужно
Flip the laptop over so the bottom is facing up.
Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
Using a spudger, separate the keyboard surface from the bottom of the laptop.
While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
Remove the keyboard assembly.
