Введение
The Touchpad assembly guide will assist the user in removal and installation within the HP Stream 13-c110nr.
Выберете то, что вам нужно
Close the device.
Remove AC adapter plug from electrical outlet.
Remove AC adapter from device.
Turn the device off.
Unplug all external devices from device.
Use a pick to remove the two (2) large computer feet along the back edge of the device.
Use a pick to remove the two (2) small computer feet.
Use a pick to remove the one (1) screw cover.
Place rubber computer feet in safe place for reassembly.
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
Remove the thirteen (13) Phillips P0 PM2.5x6.0 mm screws.
Place the thirteen (13) screws on magnetic mat for reassembly.
Turn the device over with the front facing towards you.
Open the device as shown.
Insert the Spudger between the Top Cover and Bottom Cover to lift the front edge until it separates from the Bottom Cover.
Place the Top Cover/Keyboard assembly face down with the front towards you.
Remove two (2) Phillips P0 PM2.5x3.0 mm screws from Touchpad assembly.
Place two (2) screws on magnetic mat for reassembly.
Use the plastic pick to pry up the black TouchPad cover from the blue top cover.
