Введение
Use this guide to replace the antenna near the bottom right corner of your TouchPad.
Выберете то, что вам нужно
In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
Insert a flat metal spudger in the gap between the rubber outer ring on the front panel assembly and the black plastic rear case near the USB connector.
Pry the front panel assembly up from the rear case, being careful not to damage the LCD or the glass panel.
As in the previous step, use a spudger to pry the front panel up from the rear case along its long edge on the volume button side of the TouchPad.
Continue to pry the front panel assembly up along the volume button side of the TouchPad until there is a gap between it and the rear case.
Before lifting the free side of the front panel up from the rear case, you may need to release it from the plastic retaining clips holding it down.
Use your metal spudger to pull the stuck retaining clips away from the edge of the front panel.
After freeing the retaining clips, lift the front panel assembly away from the rear case.
Use the attached black tab to pull the display data cable straight up and out of its socket on the motherboard.
Use your fingernail to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
Pull the digitizer ribbon cable straight out of its two sockets on the motherboard.
Use the edge of a plastic opening tool to peel up the two pieces of copper tape covering the USB connector board near the battery and the motherboard.
Remove the four 3.2 mm Phillips screws securing the USB connector board to the rear case.
Pry the upper end of the USB connector board upwards to disconnect it from its socket on the logic board.
Pull the USB connector board away from the bottom edge of the rear case and lift, but do not remove it out of its housing.
Pull the vibrator motor connector straight away from its socket on the USB connector board.
Remove the USB connector board from the TouchPad.
NOTE: First verify that there is a connector before pulling! The vibrator motor may be soldered directly to the USB Board requiring the motor to be pried up and removed together with the board.
Use a plastic opening tool to pry the lower antenna connector up from its socket on the motherboard.
De-route the lower antenna cable along the top edge of the battery and carefully pull it out from under its retaining clip near the top right corner of the battery.
Pull the lower antenna cable out of the plastic retaining clip molded into the rear case.
Use a plastic opening tool to peel the lower antenna off the adhesive securing it to the rear case.
Peel the foil tape attached to the lower antenna off the rear case and remove the lower antenna from the TouchPad.
