Введение
The CPU processor is the part of your device that handles multiple tasks and processes at once. If you need to replace the CPU of your HP Z2 Mini G3, follow this guide.
Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm you.
Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
Swing the fan back down and carefully unhook the CPU fan notches by pulling each tab away from the heat sink holes.
Remove the 9mm Torx screw with a T15 Torx screwdriver to release the SSD assembly.
Lift the assembly upwards to remove it.
Pull the metal arm out from under the frame and lift it up. The frame should slide back from under the screw.
