Введение
The ZBook 15 comes with a 4G wireless network module that allows you to connect to the internet via a SIM card provided by a wireless network company. If you need to replace the 4G network module on your laptop, follow this guide!
Выберете то, что вам нужно
Flip the laptop over.
Slide the lever with the battery symbol beside it firmly until the battery pops out.
Remove the battery from the laptop.
Slide the right lever firmly to the right.
Slide the cover towards yourself to remove it.
Remove the two connectors by lifting gently with a metal spudger.
Remove the 3mm screw with a Phillips #0 screwdriver.
Remove the 4G Module by lifting up and out.
3 человек успешно провели ремонт по этому руководству.
