Введение
If your HP Zbook is overheating, or getting excessively hot. It may help to clean the fan and heatsink assembly. This is the step by step guide to help you clean the heatsink to your HP ZBook 15u G2.
Выберете то, что вам нужно
Turn the HP Zbook over and flip the switch at the top so the red part is visible.
Lift the plastic tab at the top of the battery up to lift the battery up and out of the device
Use a Phillips #00 screwdriver to remove the five M2.0x2 mm screws beneath the battery.
Remove the 4 mm Phillips screws under the SD card slot on the left of the laptop.
Lift the plastic edges around the bottom of the laptop to remove the bottom plastic cover.
Loosen the 2 silver Phillips screws on the fan assembly.
Remove the 6 Phillips screws at the left side of the heatsink assembly.
Grip the heatsink assembly by the fan and lift it up to remove it.
Use computer duster to blow away and remove any dust and particles in and around the heatsink and fan assembly.
Еще один человек закончил это руководство.
