Введение
Removing the battery is usually the first step to reaching the guts of any laptop. HP has utilized a simple one-switch release system to aid in the removal of the battery.
Выберете то, что вам нужно
To reassemble your device, follow these instructions in reverse order. Note the release switch does not need to be held down to replace the battery.
4 человек успешно провели ремонт по этому руководству.
2Комментарии к руководству
Can I return a battery if it does not fit? GLOPAM2013@YAHOO.COM
what is your return policy?
