Введение
The fan is necessary for the computer to remain in operation during normal use. Overheating of any important laptop parts could result in catastrophic failure. Unfortunately, it happens to be the hardest component to access and remove.
Выберете то, что вам нужно
Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
Slide the hard drive out of the enclosure to complete the removal process.
Locate the wireless card and the two wires attached to it.
Using a plastic spudger tool, carefully lift up on each wire connecting the card to unsnap the connectors.
Locate the 2.5mm Phillips screw on the corner of the WLAN card and remove it using a Phillips #000 screwdriver.
Upon removing the screw, the WLAN card will pop up. Keeping a natural angle, slide the card out of the slot.
The card is now free from your computer.
Locate two 3mm Phillips screws on the CMOS panel cover and remove them with a Phillips #00 screwdriver.
Remove the CMOS panel cover.
The optical drive is now ready for removal. Using a plastic removal tool, lift the optical drive away from your computer.
Using your hands, slide the remainder of the drive out of the computer.
Инструмент, используемый на этом этапе:Phillips #00 Screwdriver$5.49
Remove these two 4mm Phillips screws on the back panel using a Phillips #00 screwdriver and remove the cover to reveal the CMOS battery
Инструмент, используемый на этом этапе:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Locate the CR2032 watch battery
Using a 2.5mm flathead screwdriver, carefully pry up the battery using the tab to the right of the battery
Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
Once the module is released, gently pull the module upwards.
Repeat for the RAM module underneath the first one.
Begin by unscrewing the three 3mm Phillips head screws inside the battery bay with the Phillips #00 screwdriver.
Locate the hole in between the hard drive and RAM compartments.
Unscrew the 4mm Phillips head screw from this hole.
Flip the laptop, and use the plastic opening tool on the side seam to remove the top cover.
Use a 2.5mm flathead screwdriver to remove the four 3mm screws on top of the keyboard.
Locate the ribbon cable connection between the keyboard and motherboard.
Pull upwards on the small black bar to release the ribbon cable and remove it.
Locate four 3mm screws in the upper corners of the keyboard tray and remove them using a #00 Phillips screwdriver.
Locate the two ribbon cable connectors that attach the speaker assembly to the motherboard.
Using your fingers, carefully detach the ribbon cables from the motherboard by pulling them straight out on the connector.
Locate the large display ribbon connector near the upper left corner of the keyboard tray and remove the ribbon by pulling straight out on the connector.
Locate the two final ribbon connectors for the display on the motherboard and remove them similarly by pulling straight outward on the connectors.
You are now free to remove the display from the computer.
Remove the three 3mm Phillips head screws on the top of the frame using the Phillips #00 screwdriver.
Using a plastic opening tool, carefully pry off the top plastic cover by lifting it up at the seam at various points around the edge, then remove it completely.
Remove the two 2mm screws on the bottom right of the motherboard using the Phillips #00 screwdriver.
Using the Phillips #00 screwdriver, unscrew the spring-release fasteners on the modem card and remove it from the board.
Remove the one 3mm Phillips screw on the bottom left corner of the board using the Phillips #00 Screwdriver.
Remove the motherboard from the laptop body, being careful to keep the modem board from dislodging itself.
Your motherboard is now removed.
Using the Phillips #00 screwdriver, remove the two 2.5mm screws on VGA adapter on the side of the motherboard.
Using the Phillips #00 screwdriver, unscrew the three spring releases on the heatsink part of the fan assembly.
To reassemble your device, follow these instructions in reverse order. Make sure to keep your screws separated and ensure the ribbon cables are plugged in correctly.
4 человек успешно провели ремонт по этому руководству.
2 Комментариев
How to effectively clean the fan
In a more condensed format, watch this:
https://www.youtube.com/watch?v=OpCJzdWx...
Again showing just what a pain these things are to take apart.
