Введение
If the troubleshooting procedures and all of the previous steps do not work it may be time to change the motherboard ground wire.
Выберете то, что вам нужно
Remove the screw caps using a metal spudger.
Remove the four 6 mm screws using a Phillips #0 screwdriver.
Insert a plastic opening tool into the case seam and slide it along the edges.
Lift and remove the back panel from the device.
Почти готово!
Заключение
