Введение
After following the troubleshooting procedures and the device still has no sound it may be time to replace the speaker.
Выберете то, что вам нужно
Remove the rubber screw caps using a metal spudger.
Remove the two 6mm screw using a Phillips #0 screwdriver.
Unclip each side by inserting the plastic opening tool and slide it along the edges.
Remove the back panel by lifting the panel away from the device.
Почти готово!
Заключение
