Введение
The purpose of this guide is to instruct the reader on how to replace the faceplates of their HP iPAQ H2200 device.
  1. Press and slide the battery cover tab to remove battery cover.
    • Press and slide the battery cover tab to remove battery cover.
  2. Pull on the black tab to lift the battery out of the battery compartment. Pull on the black tab to lift the battery out of the battery compartment.
    • Pull on the black tab to lift the battery out of the battery compartment.
  3. Remove the stylus by sliding it out of the slot.
    • Remove the stylus by sliding it out of the slot.
  4. Remove the CF card by sliding it out of the slot at the top of the device.
    • Remove the CF card by sliding it out of the slot at the top of the device.
  5. Press down and push the black side strips toward the top of the device to remove them.
    • Press down and push the black side strips toward the top of the device to remove them.
  6. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  7. Using the T5 Torx screwdriver,  remove all six screws on the back and all screws on each side of the device. Using the T5 Torx screwdriver,  remove all six screws on the back and all screws on each side of the device. Using the T5 Torx screwdriver,  remove all six screws on the back and all screws on each side of the device.
    • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
  8. Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side). Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
    • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
  9. Open the LCD connector, where the orange strip attaches to the main board.
    • Open the LCD connector, where the orange strip attaches to the main board.
  10. Carefully remove the orange LCD strip from the connector.
    • Carefully remove the orange LCD strip from the connector.
  11. Unscrew the 2 screws located at each top corner of the main board.
    • Unscrew the 2 screws located at each top corner of the main board.
  12. Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
    • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
  13. Unscrew the two bottom screws on LCD screen that were previously located under the main board.
    • Unscrew the two bottom screws on LCD screen that were previously located under the main board.
  14. Press on side tabs to loosen and remove the LCD screen. Press on side tabs to loosen and remove the LCD screen.
    • Press on side tabs to loosen and remove the LCD screen.
  15. Remove the faceplate by unscrewing the green screw located on the top right of the front faceplate.
    • Remove the faceplate by unscrewing the green screw located on the top right of the front faceplate.
Заключение
Tyler Andrews
Участник с: 13.01.2010
191 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 4-12, Forte Winter 2010 Member of Cal Poly, Team 4-12, Forte Winter 2010
CPSU-FORTE-W10S4G12
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 1,304
