Введение
The purpose of this guide is to instruct the reader on how to replace the faceplates of their HP iPAQ H2200 device.
Выберете то, что вам нужно
Press down and push the black side strips toward the top of the device to remove them.
Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
Unscrew the two bottom screws on LCD screen that were previously located under the main board.
Remove the faceplate by unscrewing the green screw located on the top right of the front faceplate.
