Выберете то, что вам нужно
  1. HP iPAQ H3850 disassembly for cleaning, HP iPAQ H3850 disassembly for cleaning: step 1, image 1 of 1
    • To begin the disassembly of the device, place it on a flat surface with the screen facing down.
  2. HP iPAQ H3850 disassembly for cleaning: step 2, image 1 of 1
    • Remove the four screws found on the back cover of the device.
  3. HP iPAQ H3850 disassembly for cleaning: step 3, image 1 of 1
    • Carefully remove the back cover using a plastic opening tool against the grooves along the sides of the iPAQ.
  4. HP iPAQ H3850 disassembly for cleaning: step 4, image 1 of 1
    • At this point, a yellow ribbon will be connecting both the front and back panels of the device. Carefully use the plastic opening tool to detach the ribbon from the connector pins.
  5. HP iPAQ H3850 disassembly for cleaning: step 5, image 1 of 1
    • Remove SD card on top of device by pushing and then releasing.
  6. HP iPAQ H3850 disassembly for cleaning: step 6, image 1 of 1
    • Remove ribbon cable connected to display logic board by pulling plastic clips on both sides towards top of device.
    • Use plastic opening tool to carefully pull brown ribbon cable from connector.
  7. HP iPAQ H3850 disassembly for cleaning: step 7, image 1 of 2 HP iPAQ H3850 disassembly for cleaning: step 7, image 2 of 2
    • Use plastic opening tool to carefully remove display logic board from housing.
    • Unplug connector from the opposite end of the display logic board.
    • Completely remove display logic board.
  8. HP iPAQ H3850 disassembly for cleaning: step 8, image 1 of 1
    • Flip up black plastic clip on large ribbon cable connector located towards center of mother board.
    • Use plastic opening tool to carefully remove ribbon cable from connector.
  9. HP iPAQ H3850 disassembly for cleaning: step 9, image 1 of 1
    • Locate clear/grey ribbon cable in bottom corner of device.
    • Gently pry cable out of connector with plastic pry tool.
    • Use hands or tweezers to remove if necessary.
  10. HP iPAQ H3850 disassembly for cleaning: step 10, image 1 of 1
    • Use hands to gently unplug speaker and microphone connectors from mother board.
  11. HP iPAQ H3850 disassembly for cleaning: step 11, image 1 of 1
    • Make sure no more connections exist between mother board and housing.
    • Remove three screws anchoring mother board.
    • Use hands/plastic opening tool to carefully lift mother board out of housing.
    • Place the motherboard to the side.
  12. HP iPAQ H3850 disassembly for cleaning: step 12, image 1 of 1
    • Locate 4 blue plastic clips surrounding square screen housing.
    • Pry back clips with hands.
    • Use plastic opening tool to remove entire screen assembly from housing.
    • Now that the device is completely taken apart, use a can of compressed air to clean each component of the device.
    • Be sure to put emphasis on spraying air behind the screen, as this is a common buildup spot.
Заключение
Еще один человек закончил это руководство.
Nick Hilzendeger
Участник с: 07.04.2015
404 Репутация
Автор 2 руководств
Eastern Washington University, Team 1-3, Plummer Spring 2015 Участник Eastern Washington University, Team 1-3, Plummer Spring 2015
EWU-PLUMMER-S15S1G3
4 членов
Автор 5 руководств
0 Comments
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 294
