Fix Your Stuff
Right to Repair
Parts & Tools
  1. Slide the silver release tab up and simultaneously lift the cover up from the left side.
    • Slide the silver release tab up and simultaneously lift the cover up from the left side.
  2. Push the tab from left to right to remove the cover.
    • Push the tab from left to right to remove the cover.
  3. Now lift the battery up and away from the device to remove it.
    • Now lift the battery up and away from the device to remove it.
  4. Remove the four silver screws (T5 x .25 in).
    • Remove the four silver screws (T5 x .25 in).
  5. Remove the single black screw (T5 x .125 in) beneath the HP sticker.
    • Remove the single black screw (T5 x .125 in) beneath the HP sticker.
  6. Next, use your plastic removal tool to separate the gray back from the black center piece. For better results, start the separation at the corner piece.
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  7. Remove the back case.
    • Remove the back case.
  8. Now that the back cover is removed, remove the small screw (#00 Philips x .17) to the left of the SD card slot
    • Now that the back cover is removed, remove the small screw (#00 Philips x .17) to the left of the SD card slot
  9. Next you will need to unlock and remove the ribbon cable Carefully pull back on both sides of the brown bar using metal tweezers, unlocking the cable and slipping it out of the connector
    • Next you will need to unlock and remove the ribbon cable
    • Carefully pull back on both sides of the brown bar using metal tweezers, unlocking the cable and slipping it out of the connector
    • The bar, connector, and cable are fragile components that can be easily broken
  10. Next you need to remove the wire off the bottom of the mother board The easiest method is to use some metal tweezers and grip the plug close to the connector.
    • Next you need to remove the wire off the bottom of the mother board
    • The easiest method is to use some metal tweezers and grip the plug close to the connector.
    • Make sure all these connections are properly disconnected before separation of the motherboard
  11. Next use your plastic removal tool and separate the silver front case from the black frame.
    • Next use your plastic removal tool and separate the silver front case from the black frame.
  12. Now that the front cover is removed we can detach the screen Remove the ribbon connector by pulling gently on the silver top. It will snap off the mother board.
    • Now that the front cover is removed we can detach the screen
    • Remove the ribbon connector by pulling gently on the silver top. It will snap off the mother board.
    • The ribbon cable and connector can be easily removed if you genetly lift up the motherboard to create a small gap
  13. Now the screen can be removed Now the screen can be removed Now the screen can be removed
    • Now the screen can be removed
Заключение
Еще один человек закончил это руководство.
John Pagliero
Участник с: 27.01.2011
927 Репутация
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,260
