Введение
Is your monitor not powering on? Is the power button making a weird clicking noise? You might need to replace the power button.
Инструменты
Запчасти
Детали не указаны.
  1. HP w2216h Power Button Replacement, Power Button: step 1, image 1 of 3 HP w2216h Power Button Replacement, Power Button: step 1, image 2 of 3 HP w2216h Power Button Replacement, Power Button: step 1, image 3 of 3
    • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
    • Turn monitor so that the screen is facing you.
    • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
    • The best places to pry are in the lower left and lower right corners of the black bezel.
  2. HP w2216h Power Button Replacement: step 2, image 1 of 1
    • Do not pull the screen away to hard, this could snap the power cable.
    • Remove the power button from the top of the plastic frame.
  3. HP w2216h Power Button Replacement: step 3, image 1 of 1
    • Remove the power cable by carefully sliding it out of it's plug.
    • Check if there is any tear or fray in the cable.
Заключение
Еще один человек закончил это руководство.
Sadeq Taha
Участник с: 25.03.2016
207 Репутация
1 руководство автора
UMass Dartmouth, Team 1-1, Miles Spring 2016 Участник UMass Dartmouth, Team 1-1, Miles Spring 2016
UMASSD-MILES-S16S1G1
4 членов
Автор 6 руководств
0 Comments
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 356
