Выберете то, что вам нужно
Turn off your computer before starting. Place the back of your computer face up to ensure you are facing the battery.
Remove the old battery by pulling it towards you. Replace the old battery with the new one and follow these steps in reverse order to reassemble your device.
Once you have removed the CD player port, use the spudger tool to carefully remove the back panel.
Once you remove the back panel you will see your fan on the bottom left side of your laptop.
Once the fan is unplugged from the motherboard, remove the 6 mm screws with a Phillips #1 screwdriver that are connecting the fan to the laptop. Remove the fan.
Once the fan is removed, you will see the hot plate that transfers the heat from the laptop to the fan. You will need to add thermal paste to the hot plate before placing your replacement fan back on.
Once you have placed your thermal paste on the hot plate, take your replacement fan and place it back where the old fan was. To reassemble your laptop, follow these steps in reverse order.
3 участников успешно повторили данное руководство.
