Введение
This guide is used when the speakers are damaged or do not produce sound. You will need to use a little bit of force to remove the speakers from the tablet.
Выберете то, что вам нужно
Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
Insert the tip of a plastic opening tool in the seam between the front and back panels.
Slide the plastic opening tool around all edges of the device until the back panel detaches.
Lift off the back panel.
