Введение
All phones have an antenna in them, this is what allows us to make phone calls and get signals from cell-phone towers. These fixes are generally easy, because the antennas are just small, paper-looking strips that are glued somewhere in or on the chassis of the phone.
  1. Remove the four 1.2mm screws in the corners to release the front of the phone from the back, then pry it off with the plastic opening tool.
    • Remove the four 1.2mm screws in the corners to release the front of the phone from the back, then pry it off with the plastic opening tool.
  2. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  3. Remove the back of the phone from the front.
    • Remove the back of the phone from the front.
  4. Use a spudger to gently lift one side of the antenna strip up, then pull it off. This needs to be done in all four corners.
    • Use a spudger to gently lift one side of the antenna strip up, then pull it off. This needs to be done in all four corners.
Заключение
Eric Blackstock
Участник с: 24.10.2018
379 Репутация
Автор 2 руководств
Команда
UMASSD-PEAK-F18S3G2 Member of UMASSD-PEAK-F18S3G2
Community
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 20
За всё время: 144
