Введение
Do the speakers of your HTC Desire 530 sound distorted or not work? If so, this guide will show you all the steps necessary to take a part your phone and replace the broken speakers. The only tools required for this job are a T5 Torx screwdriver and plastic opening tools.
Выберете то, что вам нужно
Use the plastic opening tools to remove the plastic speaker covers that are attached through an adhesive layer.
Use the T5 Torx screwdriver to remove the four screws in each corner.
Make sure to take out any SD cards, located on the left side of the phone before proceeding to the next step.
Use the plastic opening tool to pry the front of the device off. Fully go around the front with the plastic opening tool before attempting to pull it off.
Dislocate the small piece with the wires connected using a nylon spudger.
Loosen the adhesive layer for the battery by running a hair dryer over it briefly. After the adhesive is loosened you can pry the battery out with a plastic opening tool.
Use the T5 Torx screwdriver to remove the screw located on the left side.
Use the spudger to slowly pry off the black cover.
Slowly pry off the circuit board with the spudger in a very cautious manner.
Remove the rubber object by pinching and pulling it out.
Take the speaker out of the holder.
To access the top speaker, you must first detach the orange cable from its holder with your fingers.
Remove the T5 Torx screw.
Carefully pry off the circular object with the spudger.
Use the spudger to carefully work your way around the edge of the motherboard and slowly pry it off.
Use the spudger to pry off the speaker.
