Выберете то, что вам нужно
  1. HTC Desire 626s Backplate Replacement, Backplate: step 1, image 1 of 3 HTC Desire 626s Backplate Replacement, Backplate: step 1, image 2 of 3 HTC Desire 626s Backplate Replacement, Backplate: step 1, image 3 of 3
    • Insert plastic opening tool in between the back cover and grey plastic.
    • Gently work your way around the phone while sliding the tool.
    • Gently pry on plastic cover as needed to release fasteners.
  2. HTC Desire 626s Backplate Replacement: step 2, image 1 of 2 HTC Desire 626s Backplate Replacement: step 2, image 2 of 2
    • There are 7 screws you need to remove before prying the secondary cover off. You will need to use the JIS #000 screwdriver and the T5 Torx screwdriver to remove these screws.
    • There is a screw under the "void" sticker.
  3. HTC Desire 626s Backplate Replacement: step 3, image 1 of 2 HTC Desire 626s Backplate Replacement: step 3, image 2 of 2
    • Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
    • Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
    • This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
Заключение
Еще один человек закончил это руководство.
Blake Bartlett
Участник с: 03.04.2019
732 Репутация
Автор 6 руководств
Oregon Institute of Technology, Team S2-G7, Lancaster Spring 2019 Участник Oregon Institute of Technology, Team S2-G7, Lancaster Spring 2019
OIT-LANCASTER-S19S2G7
3 членов
Автор 12 руководств
0 Comments
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 211
