Введение
These are the instructions on how to remove and replace a broken or malfunctioning camera lens from a HTC Desire 626s smart phone. Once you remove the top layer of the back plate (step 1), you can skip straight to the lens replacement portion of this guide.
Выберете то, что вам нужно
Insert plastic opening tool in between the back cover and grey plastic.
Gently work your way around the phone while sliding the tool.
Gently pry on plastic cover as needed to release fasteners.
There are 7 screws you need to remove before prying the secondary cover off. You will need to use the JIS #000 screwdriver and the T5 Torx screwdriver to remove these screws.
There is a screw under the "void" sticker.
Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
Use tweezers to remove the outer colored cover of the lens.
Just work one end of the tweezers under the edge of the cover and gently pry it off.
Use one end of the tweezers to slip underneath one of the edges of the lens.
If the lens is already cracked you don't need to worry about being gentle with it, because the intention is to replace it.
There is adhesive holding the lens in place. Try not to scrape this up too bad because it will be used to hold the replacement lens in place.
Congrats you're done!
