Введение
If the front facing camera has become nonfunctional, it may be replaced. It is easy to check if the front facing camera is faulty; if the screen does not display an image when the front facing camera is activated via the camera application, then it is likely faulty and responsible. It may be replaced by following this step-by-step guide.
Запчасти
Детали не указаны.
  1. Use the spudger to pry the back cover off.
    • Use the spudger to pry the back cover off.
  2. Use  spudger tool to pry under the battery to lift it up and out.
    • Use spudger tool to pry under the battery to lift it up and out.
  3. Remove eight 8.3mm T4  screws with the  Torx screwdriver.
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. Pry the back panel of the screen using the plastic opener.
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
    • Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
  6. Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
    • Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
  7. Remove volume control button ribbon with tweezers.
    • Remove volume control button ribbon with tweezers.
  8. Carefully remove the ribbon attached to the top of the motherboard.
    • Carefully remove the ribbon attached to the top of the motherboard.
  9. Unsnap the wire from the printed circuit board (PCB) using the tweezers.
    • Unsnap the wire from the printed circuit board (PCB) using the tweezers.
  10. Remove the camera using the plastic opening tool as shown.
    • Remove the camera using the plastic opening tool as shown.
Заключение
Steven Pate
Участник с: 23.09.2014
191 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 9-3, Blackwell Fall 2014 Участник USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 членов
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 687
