Введение
If the rear facing camera has become nonfunctional, it may be replaced. To check if the back facing camera is faulty, open the camera application. If the screen does not display an image when the camera application is opened, then it is likely responsible and faulty. It may be replaced by following this step-by-step guide.
Запчасти
Детали не указаны.
  1. Use the spudger to pry the back cover off.
    • Use the spudger to pry the back cover off.
  2. Use  spudger tool to pry under the battery to lift it up and out.
    • Use spudger tool to pry under the battery to lift it up and out.
  3. Remove eight 8.3mm T4  screws with the  Torx screwdriver.
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. Pry the back panel of the screen using the plastic opener.
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
    • Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
  6. Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
    • Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
  7. Remove volume control button ribbon with tweezers.
    • Remove volume control button ribbon with tweezers.
  8. Carefully remove the ribbon attached to the top of the motherboard.
    • Carefully remove the ribbon attached to the top of the motherboard.
  9. Unsnap the wire from the printed circuit board (PCB) using the tweezers.
    • Unsnap the wire from the printed circuit board (PCB) using the tweezers.
  10. Carefully remove the ribbon that attaches the camera to the front screen using the tweezers and the plastic opening tool.
    • Carefully remove the ribbon that attaches the camera to the front screen using the tweezers and the plastic opening tool.
Заключение
Еще один человек закончил это руководство.
Steven Pate
Участник с: 23.09.2014
191 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 9-3, Blackwell Fall 2014 Участник USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 членов
Автор 14 руководств
Комментариев: 2
my screen conector on the motherbord got damaged what can i do about it?
stboscoojo - Ответить
On step 10, what is that big copper cover? Is it an LNA shield? What is the right tool to remove it?
Thank for this tutorial
Aissa Brahimi - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,323
