Инструменты
Запчасти
Детали не указаны.
Этот шаг не переведен. Помогите перевести
Use spudger tool to pry under the battery to lift it up and out.
Pry the back panel of the screen using the plastic opener.
Work your way gently around the device, using picks as necessary to keep the back panel separated.
Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
Carefully remove the ribbon attached to the top of the motherboard.
Unsnap the wire from the printed circuit board (PCB) using the tweezers.
Carefully remove the ribbon that attaches the camera to the front screen using the tweezers and the plastic opening tool.
Еще один человек закончил это руководство.
Комментариев: 2
my screen conector on the motherbord got damaged what can i do about it?
On step 10, what is that big copper cover? Is it an LNA shield? What is the right tool to remove it?
Thank for this tutorial
