Введение
Capturing images is how people retain visible proof of memories being created. This guides purpose is to help the user replace a major key component in a cellular device.
Выберете то, что вам нужно
Pry open the back panel by inserting the plastic opening tool on the left of the camera. We find this spot the easiest to get the tool under the panel.
Once you get an open spot, with a second plastic opening tool, slide down to the bottom of the phone to free the rest of side.
There is adhesive between the battery and the back panel. Take a nylon spudger to cut through the adhesive.
Once all way around the bottom, the panel should be broken free of the adhesive, and the rest of the panel should pop right off.
Insert a nylon spudger at the bottom of the battery and lift up to remove the battery.
There is adhesive on the other side of the battery as well, take the nylon spudger used to get off the panel and cut through.
Take the PH000 screwdriver head to take out the one screw that's holding down the green panel. (The screw is located on the left side of the panel)
Slowly lift up the white connector so that the camera’s cable may properly be detached.
Carefully peel off the adhesive so that the camera can be disconnected from the mother board
4 участников успешно повторили данное руководство.
