Введение
This guide will help you with replacing your back camera of your HTC Desire 826.
Выберете то, что вам нужно
Find a seam in the back of the device.
Insert the plastic spudger into the seam and pry off the back panel.
Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
Remove the metal bracket with the tweezers.
Use the spudger to lift the green board. The back camera is attached on the side as shown.
Use the tweezers to disconnect and remove the camera.
