Введение
This guide will show you how to replace the Navigation Board of the HTC Desire V smartphone.
Выберете то, что вам нужно
Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
Remove the connector on left side of the Navigation board by unplugging/prying the orange ribbon.
Nav Board will be stuck down by glue.
Pull gently from the right end of the board, being careful of its flexibility.
3 человек успешно провели ремонт по этому руководству.
