HTC Droid DNA Motherboard Replacement
Выберете то, что вам нужно
  1. HTC Droid DNA Motherboard Replacement, Remove the SIM Card Tray: шаг 1, изображение 1 из 1
    • Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
  2. HTC Droid DNA Motherboard Replacement, Removing the SIM Card Tray: шаг 2, изображение 1 из 2 HTC Droid DNA Motherboard Replacement, Removing the SIM Card Tray: шаг 2, изображение 2 из 2
    • Pull out the SIM Card Tray with your fingers.
  3. HTC Droid DNA Motherboard Replacement, Loosen the Phone Casing: шаг 3, изображение 1 из 2 HTC Droid DNA Motherboard Replacement, Loosen the Phone Casing: шаг 3, изображение 2 из 2
    • Make sure the USB cover on the bottom of the phone is removed first.
    • Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
    • Take your time. A lot of force is necessary to loosen the front panel.
  4. HTC Droid DNA Motherboard Replacement, Pull the Casing Apart: шаг 4, изображение 1 из 1
    • Slowly pull the panel apart from the back of the phone.
    • Apply a moderate force to pry the panel from the back of the phone.
  5. HTC Droid DNA Motherboard Replacement, Remove the Black Tape: шаг 5, изображение 1 из 1
    • Set the device down so that the bottom of the phone is facing to the right.
    • Gently take off the piece of black tape surrounding the motherboard.
    • Be careful not to rip the tape.
  6. HTC Droid DNA Motherboard Replacement, Remove the Yellow Tape: шаг 6, изображение 1 из 1
    • Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
  7. HTC Droid DNA Motherboard Replacement: шаг 7, изображение 1 из 1
    • Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
    • Use the T5 Torx screwdriver to remove the two 4mm screws located at the bottom of the phone.
  8. HTC Droid DNA Motherboard Replacement, Remove the Void Screw: шаг 8, изображение 1 из 1
    • Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
  9. HTC Droid DNA Motherboard Replacement, Remove the Screw Retaining Bracket: шаг 9, изображение 1 из 1
    • Rotate your phone back 90 Degrees counter-clockwise.
    • Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
  10. HTC Droid DNA Motherboard Replacement, Remove the Connector Screws: шаг 10, изображение 1 из 1
    • Remove the following Phillips #000 screws from the motherboard:
    • Four 1.6 mm screws
    • Two 1.5 mm screws
  11. HTC Droid DNA Motherboard Replacement, Unfasten the Connectors: шаг 11, изображение 1 из 2 HTC Droid DNA Motherboard Replacement, Unfasten the Connectors: шаг 11, изображение 2 из 2
    • Use your pry tool to unfasten the connectors on both sides of the motherboard.
    • The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
  12. HTC Droid DNA Motherboard Replacement, Remove the Yellow Tape: шаг 12, изображение 1 из 1
    • Use your tweezers to remove the two pieces of yellow tape shown.
  13. HTC Droid DNA Motherboard Replacement, Flipping up the White Board: шаг 13, изображение 1 из 2 HTC Droid DNA Motherboard Replacement, Flipping up the White Board: шаг 13, изображение 2 из 2
    • Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
  14. HTC Droid DNA Motherboard Replacement, Disconnect the Connector: шаг 14, изображение 1 из 1
    • Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cable of the Connector.
  15. HTC Droid DNA Motherboard Replacement, Flipping up the White Board: шаг 15, изображение 1 из 2 HTC Droid DNA Motherboard Replacement, Flipping up the White Board: шаг 15, изображение 2 из 2
    • Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
  16. HTC Droid DNA Motherboard Replacement, Disconnect the Connector: шаг 16, изображение 1 из 1
    • Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cables for the Connector.
  17. HTC Droid DNA Motherboard Replacement, Flipping up the White Board: шаг 17, изображение 1 из 2 HTC Droid DNA Motherboard Replacement, Flipping up the White Board: шаг 17, изображение 2 из 2
    • Rotate the phone 180 degrees.
    • Use your tweezers to gently snap up the white board on the top left of the motherboard.
  18. HTC Droid DNA Motherboard Replacement, Disconnect the Connector: шаг 18, изображение 1 из 1
    • Use your tweezers to disconnect the cable on the top left of the motherboard.
  19. HTC Droid DNA Motherboard Replacement, Flipping up the Black Board: шаг 19, изображение 1 из 2 HTC Droid DNA Motherboard Replacement, Flipping up the Black Board: шаг 19, изображение 2 из 2
    • Use your tweezers to gently snap up the black board on the top left of the motherboard.
  20. HTC Droid DNA Motherboard Replacement, Disconnect the Small Ribbon Connector: шаг 20, изображение 1 из 1
    • Use your tweezers to gently remove the yellow connector on the top left of the phone.
  21. HTC Droid DNA Motherboard Replacement, Remove the Black Wire: шаг 21, изображение 1 из 1
    • Remove the long black wire on the left of the motherboard.
  22. HTC Droid DNA Motherboard Replacement, Remove the Two Black Wires: шаг 22, изображение 1 из 1
    • Reorient the phone so that the green camera board is farthest from you.
    • Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
  23. HTC Droid DNA Motherboard Replacement, Remove the Screws: шаг 23, изображение 1 из 1
    • Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
  24. HTC Droid DNA Motherboard Replacement, Remove the Motherboard: шаг 24, изображение 1 из 2 HTC Droid DNA Motherboard Replacement, Remove the Motherboard: шаг 24, изображение 2 из 2
    • Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
Заключение
2 участников успешно повторили данное руководство.
Brandon Killian
Участник с: 10/14/14
333 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 4-43, Amido Fall 2014 Участник Cal Poly, Team 4-43, Amido Fall 2014
CPSU-AMIDO-F14S4G43
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 2,366
