HTC Droid Incredible Rear Inner Frame Replacement
Выберете то, что вам нужно
  1. HTC Droid Incredible Rear Inner Frame Replacement, Battery: шаг 1, изображение 1 из 3 HTC Droid Incredible Rear Inner Frame Replacement, Battery: шаг 1, изображение 2 из 3 HTC Droid Incredible Rear Inner Frame Replacement, Battery: шаг 1, изображение 3 из 3
    • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
    • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
  2. HTC Droid Incredible Rear Inner Frame Replacement: шаг 2, изображение 1 из 1
    • Remove the rear panel from the phone.
  3. HTC Droid Incredible Rear Inner Frame Replacement: шаг 3, изображение 1 из 3 HTC Droid Incredible Rear Inner Frame Replacement: шаг 3, изображение 2 из 3 HTC Droid Incredible Rear Inner Frame Replacement: шаг 3, изображение 3 из 3
    • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  4. HTC Droid Incredible Rear Inner Frame Replacement, MicroSD card: шаг 4, изображение 1 из 2 HTC Droid Incredible Rear Inner Frame Replacement, MicroSD card: шаг 4, изображение 2 из 2
    • Press the MicroSD card further into its slot until it clicks.
    • Release the MicroSD card, and it will pop out slightly.
  5. HTC Droid Incredible Rear Inner Frame Replacement: шаг 5, изображение 1 из 2 HTC Droid Incredible Rear Inner Frame Replacement: шаг 5, изображение 2 из 2
    • Pull the MicroSD card straight out of its slot.
  6. HTC Droid Incredible Rear Inner Frame Replacement, Rear Inner Frame: шаг 6, изображение 1 из 1
    • Remove four T6 Torx screws securing the rear inner frame to the front case.
  7. HTC Droid Incredible Rear Inner Frame Replacement: шаг 7, изображение 1 из 1
    • The rear inner frame is attached to the front case by nine plastic clips, marked here for reference.
  8. HTC Droid Incredible Rear Inner Frame Replacement: шаг 8, изображение 1 из 2 HTC Droid Incredible Rear Inner Frame Replacement: шаг 8, изображение 2 из 2
    • Starting on the bottom of the phone, gently push in on the (red) rear inner frame behind each black clip with a small flathead screwdriver.
    • Go slow and be gentle, you may have to go back and forth between each side several times to work the rear inner case free.
  9. HTC Droid Incredible Rear Inner Frame Replacement: шаг 9, изображение 1 из 2 HTC Droid Incredible Rear Inner Frame Replacement: шаг 9, изображение 2 из 2
    • Loosen the clips on the side next to the camera using the method described in the previous step.
  10. HTC Droid Incredible Rear Inner Frame Replacement: шаг 10, изображение 1 из 2 HTC Droid Incredible Rear Inner Frame Replacement: шаг 10, изображение 2 из 2
    • Rotate the phone 180 degrees and loosen the three clips on the side by the speaker. Note that the middle clip on this side is smaller than the others.
  11. HTC Droid Incredible Rear Inner Frame Replacement: шаг 11, изображение 1 из 3 HTC Droid Incredible Rear Inner Frame Replacement: шаг 11, изображение 2 из 3 HTC Droid Incredible Rear Inner Frame Replacement: шаг 11, изображение 3 из 3
    • Use the same technique to loosen the clip on the top of the phone.
    • You may need to gently lift the bottom of the rear inner frame to free this clip.
  12. HTC Droid Incredible Rear Inner Frame Replacement: шаг 12, изображение 1 из 2 HTC Droid Incredible Rear Inner Frame Replacement: шаг 12, изображение 2 из 2
    • Remove the rear inner frame.
Заключение
Еще один человек закончил это руководство.
Andrew Optimus Goldheart
Участник с: 10/17/09
502 786 Репутация
Автор 407 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 767 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 990
