Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Remove the back case of the phone with a plastic opening tool by placing the tool in the tab on the back of the phone.
Remove the battery from the phone by carefully lifting it out with your fingers.
you should remove the six T5 screws holding the Inner frame in place. Be careful not to loose the screws
Using the plastic opening tool again, gently pry the inner frame apart from the rest of the phone
Remove the inner frame from the rest of the phone by lifting it off
use plastic pic to gently pry our the speaker
be sure to have your replacement unit ready
