Запчасти и средства модернизации
Шаги в этом руководстве следует разделить и объединить в серию обязательных руководств.
Введение
Перейти к шагу 1 ↓Replacing this component requires intricacy and caution with moving internal parts and circuitry inside the phone to avoid further damage to the other functionalities. Proceed with caution using a soldering iron used to detach the charging port.
Выберете то, что Вам нужно
Инструменты
Инструмент, используемый на этом этапе:Tweezers$4.99
Tools: Phillips #000 Screwdriver, T4 Torx Screwdriver, Safety Pry Tool (Guitar pick), Tweezers
Use fingers on either end of the button edges of the phone to pull back cover off. It should slide off.
When open, pull on “Open” tab and it should rotate towards you
Grab the bottom edge of the battery and pull it toward you
On the side of the top casing on the phone there should be a slot. Use your safety pry tool (guitar pick) pry around the perimeter of the casing to remove it
Info*: The adhesive tape that you may find will not be necessary for replacement later
Remove the two Phillips screws to release the casing above the port
Remove the top and bottom pairs of Torx screws.
Remove the middle pair of two Phillips screws.
To remove the remaining cover, lift the side port, which was previously uncovered, then lift the outer shell from the bottom of the phone and slide it forward
Remove the two revealed screws on the outside (Torx = red, Phillips = orange), and then remove the two phillips on the bottom of the phone
Remove the rear housing by prying around the edge with your Safety Pry Tool
Unplug the wire connecting the vibrator to the board with your tweezers
The flex cables should be the only binding and after being removed should leave you with the separate screen
Инструмент, используемый на этом этапе:Desoldering Pump$3.99
Use solder sucker to remove solder from the back of charging port
Use solder sucker to remove solder from the front of charging port
There are 2 soldering locations from the top view and 4 locations from the bottom view
