Введение
In this guide we will show how to replace the screen on an HTC Evo 3D. This will include disassembling internal features of the phone in order to remove the screen.
Запчасти
Детали не указаны.
  1. HTC Evo 3D Screen Replacement, Motherboard: step 1, image 1 of 3 HTC Evo 3D Screen Replacement, Motherboard: step 1, image 2 of 3 HTC Evo 3D Screen Replacement, Motherboard: step 1, image 3 of 3
    • Remove the outer casing of the phone with your hands by prying and lifting at the latch.
  2. HTC Evo 3D Screen Replacement: step 2, image 1 of 2 HTC Evo 3D Screen Replacement: step 2, image 2 of 2
    • Remove the battery with your hands, lifting at the marked area.
    • Remove the SD card by gently pulling down on the bottom of the card.
  3. HTC Evo 3D Screen Replacement: step 3, image 1 of 1
    • Remove the four T5 screws using the corresponding screwdriver.
    • Remove the two J000 screws using the corresponding screwdriver.
  4. HTC Evo 3D Screen Replacement: step 4, image 1 of 2 HTC Evo 3D Screen Replacement: step 4, image 2 of 2
    • With the battery, SD card, and screws removed, the inner case of the phone can now be removed.
    • Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
    • This will remove the inner case, and allow access into the inner portion of the phone.
    • Be sure not to rip or damage the ribbons inside this shell.
  5. HTC Evo 3D Screen Replacement: step 5, image 1 of 3 HTC Evo 3D Screen Replacement: step 5, image 2 of 3 HTC Evo 3D Screen Replacement: step 5, image 3 of 3
    • Pictured here is the motherboard.
    • Using precision tweezers, remove the flash mechanism by prying the sides of the piece.
  6. HTC Evo 3D Screen Replacement: step 6, image 1 of 3 HTC Evo 3D Screen Replacement: step 6, image 2 of 3 HTC Evo 3D Screen Replacement: step 6, image 3 of 3
    • Next we will remove the vibration mechanism shown here.
    • Using precision tweezers or fingers, gently pull on the wires connecting the vibration mechanism to the motherboard.
    • The piece should come loose easily.
  7. HTC Evo 3D Screen Replacement: step 7, image 1 of 3 HTC Evo 3D Screen Replacement: step 7, image 2 of 3 HTC Evo 3D Screen Replacement: step 7, image 3 of 3
    • The next step is to disconnect all ribbons attached to the motherboard.
    • Begin by using tweezers to remove the plastic covering the ribbons.
    • Each ribbon needs to be removed by unlocking the white tab and pulling on the ribbon.
    • Unlock by lifting the white tab directly up.
    • The ribbons easily rip and require careful handling.
  8. HTC Evo 3D Screen Replacement: step 8, image 1 of 2 HTC Evo 3D Screen Replacement: step 8, image 2 of 2
    • At this point the motherboard is almost fully detached.
    • Lift the motherboard and using precision tweezers, peel up the insulation cover on the bottom left corner.
  9. HTC Evo 3D Screen Replacement: step 9, image 1 of 3 HTC Evo 3D Screen Replacement: step 9, image 2 of 3 HTC Evo 3D Screen Replacement: step 9, image 3 of 3
    • Disconnect the two ribbons on the backside of the mother board using precision tweezers.
    • Disconnect the Cellular/WIFI antenna by pulling directly up on the black wire.
    • The motherboard will now be free from the rest of the phone.
  10. HTC Evo 3D Screen Replacement, Screen: step 10, image 1 of 1
    • Once the motherboard is removed, heat up the frame of the screen for 30 seconds with a heat gun or a hair dryer. This will make removal easier.
    • Be careful not to overheat the device.
    • Use the plastic opening tool to pry open up one side of the screen.
    • Use the plastic opening tool to move around the borders and loosen the screen.
  11. HTC Evo 3D Screen Replacement: step 11, image 1 of 2 HTC Evo 3D Screen Replacement: step 11, image 2 of 2
    • Use the suction cup to remove the screen off the device.
    • Be careful not to tear off the flex cable.
    • After lifting the screen, begin prying the digitizer using a plastic opening tool.
    • Continue with this process around the entire perimeter of the phone.
  12. HTC Evo 3D Screen Replacement: step 12, image 1 of 2 HTC Evo 3D Screen Replacement: step 12, image 2 of 2
    • Once all the adhesive is separated, carefully remove the screen from the device.
    • Due to the removal of the motherboard, the screens should be easily removed from the phone.
    • Be careful not to cut off the flex cables or the tape.
    • If needed, use heat to make the removal of the tape and cables easier.
Заключение
6 участников успешно повторили данное руководство.
Carlos De Lima
Участник с: 26.08.2015
347 Репутация
1 руководство автора
Команда
USF Tampa, Team 14-20, Meier Fall 2015 Участник USF Tampa, Team 14-20, Meier Fall 2015
USFT-MEIER-F15S14G20
5 членов
Автор 10 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 1,185
