Введение
Use this guide to replace a worn-out battery on your Evo 4G.
Выберете то, что вам нужно
Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
Using the tip of your finger, lift the battery from the end closest to the camera.
Remove the battery from the rear inner frame.
10 участников успешно повторили данное руководство.
