Введение
Replace a faulty or worn-out kickstand.
Запчасти
Никакие детали не требуются.
  1. Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
    • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
    • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
  2. Lift the rear panel off of the inner rear frame.
    • Lift the rear panel off of the inner rear frame.
  3. Using the tip of your finger, lift the battery from the end closest to the camera. Remove the battery from the rear inner frame.
    • Using the tip of your finger, lift the battery from the end closest to the camera.
    • Remove the battery from the rear inner frame.
  4. Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
    • Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
    • The retainer will move about 1 mm and stop. Do not attempt to completely remove the MicroSD card retainer.
  5. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  6. Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
    • Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
  7. Remove six T5 Torx screws securing the rear inner frame to the inner case.
    • Remove six T5 Torx screws securing the rear inner frame to the inner case.
  8. Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
    • Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
    • Carefully pry the top edge of the rear inner frame away from the front surround of the Evo.
  9. Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo. Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
    • Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
  10. Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo. Pry up the rear inner frame along the right edge using the method described in previous steps. Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
    • Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
    • Pry up the rear inner frame along the right edge using the method described in previous steps.
    • Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
  11. Remove the rear inner frame from the rest of the Evo.
    • Remove the rear inner frame from the rest of the Evo.
  12. Remove the five Phillips screws securing the kickstand to the rear inner frame. Remove the kickstand from the rear inner frame.
    • Remove the five Phillips screws securing the kickstand to the rear inner frame.
    • Remove the kickstand from the rear inner frame.
Заключение
12 участников успешно повторили данное руководство.
Комментариев: 2
Where can you buy a replacment Kickstand for the HTC EVO ?
danielhana - Ответить
where do you get a new kickstand
Tom - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 5
За всё время: 20,699
