Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If your Fortress' camera is malfunctioning and you've ruled out any software problems, you may want to install a new Camera.
In this guide, you'll learn how to install the HTC Fortress camera. This guide requires a moderate amount of dismantling of your phone with tools from the iFixit tool kit.
Выберете то, что вам нужно
Remove the top 2 screws on the back of the phone with the T4 Screwdriver.
Remove the camera panel by hand (black cover above the battery slot).
During reassembly, put the cable back in by holding the black piece slightly above its slot and using the spudger to gently press the end of the cable back into its fitting. Then, insert the black piece so it is flush with the black panel again.
Work the metal camera casing off by slowly prying up the sides using the spudger.
Еще один человек закончил это руководство.
