Введение
This guide demonstrates how to propery remove and replace the front panel of an HTC HD 2.
Выберете то, что вам нужно
Use a small Philips screwdriver to remove the four indicated screws.
Use a pry tool along the edges of the device to remove the broken or non-functional screen.
Carefully pull the flex cable connections.
Danach 3 tesa stripes lösen
Using tweezers, release the 3 tesa strips.
Kabel vorsichtig aus dem Kabelschacht ...
Carefully remove the cable from its shaft.
