HTC Incredible 2 SIM Card Replacement
  1. HTC Incredible 2 SIM Card Replacement, Disassembling HTC Incredible 2 Back Panel: шаг 1, изображение 1 из 2 HTC Incredible 2 SIM Card Replacement, Disassembling HTC Incredible 2 Back Panel: шаг 1, изображение 2 из 2
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
  2. HTC Incredible 2 SIM Card Replacement: шаг 2, изображение 1 из 1
    • Remove the rear panel from the phone.
  3. HTC Incredible 2 SIM Card Replacement, Battery: шаг 3, изображение 1 из 1
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
  4. HTC Incredible 2 SIM Card Replacement: шаг 4, изображение 1 из 2 HTC Incredible 2 SIM Card Replacement: шаг 4, изображение 2 из 2
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  5. HTC Incredible 2 SIM Card Replacement, SIM Card: шаг 5, изображение 1 из 2 HTC Incredible 2 SIM Card Replacement, SIM Card: шаг 5, изображение 2 из 2
    • Apply pressure with your fingertip to the pressure clip beneath the SIM card.
    • While keeping pressure on the clip, use another finger to gently slide the SIM card down over the clip.
  6. HTC Incredible 2 SIM Card Replacement: шаг 6, изображение 1 из 2 HTC Incredible 2 SIM Card Replacement: шаг 6, изображение 2 из 2
    • Keep sliding SIM card until completely free from holding apparatus. Now remove the SIM card.
Заключение
William Slope
Участник с: 04/22/14
130 Репутация
1 руководство автора
Команда
Cal Poly, Team 11-53, Amido Spring 2014 Участник Cal Poly, Team 11-53, Amido Spring 2014
CPSU-AMIDO-S14S11G53
5 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 1,225
