Введение
Having trouble adjusting the phone's volume? This guide will walk you through the steps of how to access and replace the audio controls.
Запчасти
Детали не указаны.
  1. Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail. With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
  2. Remove the rear panel from the phone.
    • Remove the rear panel from the phone.
  3. Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
  4. Gently lever the battery up and away from the lights. Lift the top of the battery up and remove the battery from the rear inner frame.
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
  5. Remove the seven 1.42 mm Torx T5 screws
    • Remove the seven 1.42 mm Torx T5 screws
  6. Use a plastic opening tool to run along the phone's side and lever mid panel upward. Apply minimal pressure as the mid panel is very delicate.
    • Use a plastic opening tool to run along the phone's side and lever mid panel upward.
    • Apply minimal pressure as the mid panel is very delicate.
  7. Gently grasp and carefully lift mid panel up and away from the device with your fingers.
    • Gently grasp and carefully lift mid panel up and away from the device with your fingers.
  8. Firmly grasp the volume button from the mid panel on the clip side Gently lift the button upwards and remove it Gently lift the button upwards and remove it
    • Firmly grasp the volume button from the mid panel on the clip side
    • Gently lift the button upwards and remove it
Заключение
2 участников успешно повторили данное руководство.
Robert Trujillo
Участник с: 25.04.2014
246 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 11-53, Amido Spring 2014 Участник Cal Poly, Team 11-53, Amido Spring 2014
CPSU-AMIDO-S14S11G53
5 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 275
