Введение
A part that might fail after you drop your HTC Magic is the speaker. Here's how to replace it. You will need Torx T6 & T5 drivers , a screwdriver, & a iPod opening tool(s).
Запчасти
Никакие детали не требуются.
  1. Open the phone by removing it's backcover (battery door) and the battery. REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage. REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage.
    • Open the phone by removing it's backcover (battery door) and the battery.
    • REMEMBER to remove the simcard and microSD card. If you do not they'll be damaged when you remove them at a later stage.
  2. Unscrew the six screws with a Torx T5 screwdriver.
    • Unscrew the six screws with a Torx T5 screwdriver.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Remove the antenna (use the little gap at the top ). Remove the antenna (use the little gap at the top ).
    • Remove the antenna (use the little gap at the top ).
    • Use the iPod opening tools (or your fingernails) to remove the hosuing by running along the seam bit by bit. It's easiest to start somewhere in the middle, then work your way across the top.
    • The housing is held by plastic clips, so be careful since you don't want to break these.
    • Carefully lift the front housing from the back.
  5. The rear housing should look like the picture on the left. The speaker part is at the top. Use a small bit (like a paperclip) to lift the speaker out of it's socket. It's glued in it's place, so you may need to use a bit of force.
    • The rear housing should look like the picture on the left. The speaker part is at the top.
    • Use a small bit (like a paperclip) to lift the speaker out of it's socket. It's glued in it's place, so you may need to use a bit of force.
    • Be sure not to touch any part of the speaker except the black plastic parts.
Заключение
LucasJV
Участник с: 18.05.2010
699 Репутация
Автор 3 руководств
Команда
Verheij.co Member of Verheij.co
Business
1 член
Автор 3 руководств
Один комментарий
Where can I buy a speaker's set for the HTC Magic, please?
Miguel Ponce - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 2
За всё время: 10,550
