Запчасти
Детали не указаны.
Этот шаг не переведен. Помогите перевести
First remove the back cover of your phone to expose the battery.
Turn the phone over.
Push forward on the battery with your thumb.
Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone.
Remove the two 4.3mm Phillips #00 screws that secure the back panel to the rest of the phone.
Insert the plastic opening tool along the seams at different points to it pry the clips off.
Use your finger or the plastic opening tool to unclip the board.
Flip up the retaining flap with your fingernail or a plastic opening tool.
Pull on the ribbon cable gently with your fingers.
Split apart the motherboard and front panel.
Remove the other yellow piece of tape off of the end of the ribbon cable.
Gently pull on the ribbon cable to separate the motherboard.
Locate the internal speaker at the top center of the phone.
Using the plastic opening tool, carefully pry out the internal speaker.
