Введение
Use this guide to replace the SIM card on your HTC One M8.
Выберете то, что вам нужно
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the upper left hand side of the phone.
Press to eject the tray.
Remove the SIM card tray assembly from the HTC One M8.
Another easy step if you have the right tool
6 участников успешно повторили данное руководство.
Один комментарий
na die sim bekomme ich ohne Anleitung ausgetauscht-ich muss meinen simkartenleser/simslot austauschen und bin gerade auf der Suche nach der Anleitung-gibts die hier auch?
I just successfully completed the battery replacement on m8 using this guide…thought I would add a comment at each step to follow my story. This step of course should be easy if you’ve put the phone back together.
Ashley Keith (sc0rch3d) - Ответить
My HTC m8 doesn’t have a SIM card, and it might not have a micro SD card, since i can’t back anything up on it. Does not having the SIM card or the micro SD card matter in disassembly and reassembly?
Lewwy Ignovoir - Ответить
