Введение
Use this guide to replace the headphone jack/micro USB board on your HTC One M9.
Выберете то, что вам нужно
The microSD card tray is located on the upper right hand side of the phone, above the volume buttons. To open the tray, insert a microSD card eject tool, or a paperclip, into the small hole in the microSD card tray.
Then press the tool or paperclip to eject the microSD card tray.
Insert a SIM card eject tool or a paperclip into the small hole besides the SIM card tray, located on the upper section of the left edge of the phone.
Press to eject the tray.
Using a plastic opening pick or a spudger, gently pry and remove the cover on top of the case.
Remove the two 4 mm T5 Torx screws on the top of the case.
Work a plastic opening pick around the perimeter of the device to separate the rear case from the display assembly.
Use a pair of tweezers to get underneath the white and blue cable connectors and gently push them upwards to disconnect them.
Remove the two 1.5 mm screws that secure the battery connector to the motherboard, using a Phillips #00 screwdriver.
Use a spudger to gently pry up the battery connector from its socket.
Peel back the Kapton tape from the ZIF connectors.
Use a spudger or your fingernail to lift the hinged retainer clips on the ZIF connectors, and gently slide the cables out.
Using the tweezers, carefully lift the tape covering the electrical strip, as shown in the picture.
Use a spudger or your fingernail to lift the hinged retainer clip on the ZIF connector, and slide the cable out.
Peel back the Kapton tape from the remaining three ZIF connectors, then use a spudger or your fingernail to lift the hinged retainer clips on the ZIF connectors, and slide the cables out from each.
Remove the dual LED flash cover with a pair of tweezers. The cover is held on with a small amount of adhesive.
Use a pair of tweezers to disconnect the two antenna cables near the camera.
Disconnect the antenna cable near the bottom right of the phone.
Use a pair of tweezers to lift the vibrator out of its slot.
Use an iOpener or heat gun to loosen the adhesive at the bottom of the motherboard.
Use a plastic opening tool, or a spudger, along the edges of the case to gently pry the motherboard out of the case.
Gently lift the motherboard out of the case, beginning from the top corner (near the camera).
Remove the 3 mm T5 screw that holds the front speaker in place.
Gently remove the speaker from the device.
Use a pair of tweezers to remove the headphone jack/micro USB board.
10 участников успешно повторили данное руководство.
Один комментарий
Hi,
Make sure to check the headphone board too see if the gps connection in your phone has 1 or 2 cable ports.(Blue jumper wires) Mine has 1 so I got a sim card error. Waiting for usb board with one cable to fix
