Введение
This guide is to help you get into your device to replace the power and volume buttons. This is for replacing the actual component, not the outer plastic pieces.
Инструменты
Запчасти
Никакие детали не требуются.
Insert the end of a paper clip into the holes on each side of the phone to eject the SIM card and Micro SD card.
Set the cardholders aside.
Use a metal spudger to pry up the left edge of the upper grey front plate.
Use the narrow plastic pry tool to carefully separate the black ribbon antenna from the grey plate.
Use the plastic pry tool to pry around the edge of the phone.
Slowly pull up from the right side of the screen like opening a book.
Use the plastic spudger to peel the foam adhesive around the camera away from the back plate.
Use the pointed end of a spudger to peel the yellow tape off of the power button connector.
Using the pointed end of the spudger, pop up the small white tab on the power button connector.
Gently pull the ribbon cable out of the connector.
Use a plastic opening tool to pry under the green mini circuit board to peel off the power button.
Use the pointed end of a spudger to peel off the yellow tape from the volume button connector.
6 участников успешно повторили данное руководство.
Один комментарий
HTC One Mini (not Mini 2) doesn't have the zif connector for its power and volume flex cables but directly connected to board. can you suggest an easy way to replace them? I have found the replacement parts but don't know if I could do it in home or not. thanks
