Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This repair guide will show you step-by-step how to take off the rear casing of your HTC One Mini and safely remove your current rear camera.
Запчасти
Детали не указаны.
  1. Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
    • Use an iOpener or hair dryer to apply heat to the lower speaker grille, in order to soften the adhesive underneath.
  2. Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
    • Slide a thin pry tool underneath the lower speaker cover and slide it across to separate the adhesive underneath.
    • Remove the lower speaker cover.
  3. Remove the screw under the speaker cover using a T6 Torx screwdriver. Remove the screw under the speaker cover using a T6 Torx screwdriver. Remove the screw under the speaker cover using a T6 Torx screwdriver.
    • Remove the screw under the speaker cover using a T6 Torx screwdriver.
  4. Slide a thin guitar pick or pry tool between the edge of the display and the rear case, near the bottom of the phone. Carefully work your way up each side of the display and separate the rear case. There are three clips on each side. Carefully work your way up each side of the display and separate the rear case. There are three clips on each side.
    • Slide a thin guitar pick or pry tool between the edge of the display and the rear case, near the bottom of the phone.
    • Carefully work your way up each side of the display and separate the rear case. There are three clips on each side.
  5. Remove the rear case from the phone. Remove the rear case from the phone.
    • Remove the rear case from the phone.
  6. Remove the two Phillips screws securing the battery connector. Remove the two Phillips screws securing the battery connector. Remove the two Phillips screws securing the battery connector.
    • Remove the two Phillips screws securing the battery connector.
  7. Disconnect the battery by prying the metal cover straight up. Disconnect the battery by prying the metal cover straight up.
    • Disconnect the battery by prying the metal cover straight up.
  8. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  9. Remove two Phillips screws. Remove two Phillips screws. Remove two Phillips screws.
    • Remove two Phillips screws.
  10. Remove the two small black Phillips screws. Remove the two small black Phillips screws. Remove the two small black Phillips screws.
    • Remove the two small black Phillips screws.
  11. Remove two more Phillips screws. Remove two more Phillips screws. Remove two more Phillips screws.
    • Remove two more Phillips screws.
  12. Use tweezers to remove the yellow tape covering the flex cable connectors (total of five). Use tweezers to remove the yellow tape covering the flex cable connectors (total of five). Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
    • Use tweezers to remove the yellow tape covering the flex cable connectors (total of five).
  13. Carefully disconnect the flex cables at the points where you removed the yellow tape in the previous steps. To disconnect, flip up the small latch on each connector, opposite its cable, and then gently pull the cable free.
    • Carefully disconnect the flex cables at the points where you removed the yellow tape in the previous steps.
    • To disconnect, flip up the small latch on each connector, opposite its cable, and then gently pull the cable free.
  14. Peel off the silver strip with your tweezers. Using your hands, detach the black strip from the board without removing it. Using your hands, detach the black strip from the board without removing it.
    • Peel off the silver strip with your tweezers.
    • Using your hands, detach the black strip from the board without removing it.
  15. Detach carefully with your tweezers the volume buttons. Detach the power button with your tweezers.
    • Detach carefully with your tweezers the volume buttons.
    • Detach the power button with your tweezers.
  16. Identify the screw behind the cable. Remove the screw using a Phillips screwdriver. Remove the screw using a Phillips screwdriver.
    • Identify the screw behind the cable.
    • Remove the screw using a Phillips screwdriver.
  17. Lift the motherboard, but don't try to remove it completely yet. Handle the board only by the edges.
    • Lift the motherboard, but don't try to remove it completely yet.
    • Handle the board only by the edges.
  18. Using your tweezers, remove the black square located in the power button. Remove the motherboard completely. Remove the motherboard completely.
    • Using your tweezers, remove the black square located in the power button.
    • Remove the motherboard completely.
  19. Remove the motherboard and place it so that the rear camera is face down.
    • Remove the motherboard and place it so that the rear camera is face down.
  20. Use the tweezers to carefully peel back the copper tape attached to your rear camera.
    • Use the tweezers to carefully peel back the copper tape attached to your rear camera.
  21. Use the tweezers to lift the hatch and remove the part of the rear camera that is inserted. Use the tweezers to lift the hatch and remove the part of the rear camera that is inserted. Use the tweezers to lift the hatch and remove the part of the rear camera that is inserted.
    • Use the tweezers to lift the hatch and remove the part of the rear camera that is inserted.
Заключение
2 участников успешно повторили данное руководство.
Marina Sanchez
Участник с: 22.09.2014
190 Репутация
1 руководство автора
Команда
USF Tampa, Team 3-4, Brown Fall 2014 Участник USF Tampa, Team 3-4, Brown Fall 2014
USFT-BROWN-F14S3G4
3 членов
Автор 5 руководств
Комментариев: 2
What glue does one use when putting back the speaker grill?
Ratfink - Ответить
where can I get the rear camera? what is te number part. tks
Sinuhe Less - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 2,937
