Выберете то, что вам нужно
Use the plastic opening tool to loosen the adhesive from the crease surrounding the screen.
Wedge the plastic opening tool into the crack around the screen, on only the top, left and right sides.
Once the screen has been loosened on the top, left and right edges, lift the screen. It will remain attached at the bottom on a hinge.
Carefully remove the volume button. Loosen the back panel of the phone with the plastic opening tool. Begin loosening and prying in the space where the battery was.
Once the crease has been loosened all around, pry the back panel open and lift until it can be removed.
Инструмент, используемый на этом этапе:Tweezers$4.99
Reach beneath the motherboard with the tweezers, grip it and lift.
Remove the tape connecting the motherboard to the phone and gently lift it out.
14 человек успешно провели ремонт по этому руководству.
