HTC One Motherboard Replacement
Выберете то, что вам нужно
  1. HTC One Motherboard Replacement, Front Panel: шаг 1, изображение 1 из 1
    • Use the plastic opening tool to loosen the adhesive from the crease surrounding the screen.
    • The volume button is a good place to begin, it should come right out as you pry.
  2. HTC One Motherboard Replacement: шаг 2, изображение 1 из 1
    • Wedge the plastic opening tool into the crack around the screen, on only the top, left and right sides.
    • Applying heat with the iOpener or a heat gun can speed this process.
  3. HTC One Motherboard Replacement: шаг 3, изображение 1 из 1
    • Once the screen has been loosened on the top, left and right edges, lift the screen. It will remain attached at the bottom on a hinge.
    • The screen will remain attached to this hinge until the final step.
  4. HTC One Motherboard Replacement: шаг 4, изображение 1 из 1
    • Carefully remove the volume button. Loosen the back panel of the phone with the plastic opening tool. Begin loosening and prying in the space where the battery was.
  5. HTC One Motherboard Replacement: шаг 5, изображение 1 из 1
    • Once the crease has been loosened all around, pry the back panel open and lift until it can be removed.
  6. HTC One Motherboard Replacement: шаг 6, изображение 1 из 1
    • Remove tape to expose #000 screws, remove all screws.
    • Use the #000 bit screwdriver
  7. HTC One Motherboard Replacement: шаг 7, изображение 1 из 1
    • Reach beneath the motherboard with the tweezers, grip it and lift.
    • Lift with care, the motherboard is not completely disconnected yet.
    • Remove the tape connecting the motherboard to the phone and gently lift it out.
Заключение
14 участников успешно повторили данное руководство.
Meghan
Участник с: 09/23/14
479 Репутация
1 руководство автора
Команда
USF Tampa, Team 12-1, Blackwell Fall 2014 Участник USF Tampa, Team 12-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G1
4 членов
Автор 7 руководств
2 Комментариев
Where can I buy a motherboard to do the replacement?
Askateth - Ответить
Will changing the motherboard fix the pink tint in my camera?
mmm50592 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 12
За всё время: 14,941
