Введение
HTC One X is also known as S720E.
How to disassemble the phone and change the LCD Display & Touchscreen / Digitizer (the complete spare part).
Выберете то, что вам нужно
Видео обзор
Switch-off the phone (if you can).
Remove the SIM tray.
The back cover is sticked to the phone with adhesive tape. Is good to use some hot air to do removing of the back cover easier.
Disconnect one by one:
the Touchscreen flex cable
the Volume buttons & Mic flex cable
the Dock connector flex cable
Use a plastic tool to unstick the battery.
Now you can separate the Dock flex cable.
Lift the motherboard slightly to disconnect two flex cables:
the LCD Display flex cable
the Navigation buttons flex cable
Disconnect the Power On button flex cable at the upper side of the phone
Now the mainboard and the battery are free.
Disconnect the battery from the mainboard.
At the beginning you can use a cutter to make a room for the plastic tool.
During the procedure of the separating the LCD Display & Touchscreen from the frame, you can use again hot air. This will make separating more easy.
The original adhesive tape is left on the frame, but I prefer to put new. I put it onto the original.
Gently assemble the screen to the frame.
14 участников успешно повторили данное руководство.
