Введение
If your top speaker doesn't work then replacement may be the best option.
Выберете то, что вам нужно
Hold down the power button to turn off your device.
Insert a pin, paper clip, or another similar object into the hole next to the micro sim card holder to remove it.
Using plastic opening tools, pry open the bottom of the device.
You will hear clicking sounds as the sides of the device detach from the screen.
Once both sides are detached use the suction cup tool to remove the screen completely from the black casing.
Remove the five 2.4mm screws located around the camera using a Philips head screwdriver to remove the plastic cover.
Use the J000 Philips screwdriver to remove the screws and remove the PCB board and antenna.
These are two 3.4mm Philips head screws found in the lower right corner of the phone.
Pull out the power button flex cable using tweezers to disconnect from the phone.
Use the tweezers to then disconnect the touch screen flex cable.
Remove the battery connections to the logic board.
This is the six pin connector seen in the red box.
Pull the battery away to remove from the back of the screen.
Еще один человек закончил это руководство.
